Fixed an old Maytag MDB PCB assembly
I had the flickering light symptoms. These forums pointed me to the PCB assembly. I thought I would have a look at the old one first before ordering a new one. The new ones are expensive. I found a very obvious loose solder joint on one of the big blue relays. Re-soldered it and all is well. I did not even have to take the board all the way out to do it. Just removed one 1/4" hex head screw, all the connecters to that sub-board, released the four tabs and flipped it over.
Hope this helps
Todd K.
Good find!
It’s always worth looking over any board for loose solder connections before replacing it.
Thanks for posting.
