Fix whirlpool dishwasher
normal wash cycle quit functioning. was told it was control board. put a n ew one in and it functioned the same way. we had been washing dishes with the quick wash cycle and had been getting by but when i first put new control board in the first time we wash it ran the same as with the old board but now even quick wash is not functioning. please advise what my next step should be. i priced the control panel and it may be cost prohibitive? 175.00 Thanks, Eric
the only thing i can think of is to make the door latch is working correctly but i dont think that would be the cause of the problem - wouldnt hurt to check though it could always be an intermittent door latch problem
Replacement parts for WHIRLPOOL GU1200XTLQ0 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208533399.pdf
As Qtip said, it could be a door latch switch.
Could be that the thermal fuse has blown (Item 6 in Section 2)
Check that the unit is getting power re: wirenuts etc.are OK.
On the original problem, check the keypad with a meter, see the tech sheet.
Normally the way you trouble shoot this type of problem is to check the keypad and if it is OK then you replace the control board. Still a bit of a crap shoot but your odds are better.
You may want to try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
