Fisher Paykel
I was wondering if anyone could help diagose the following problems:
Machine powers on. All lights on circuit board light up appropriately. Wash cycle starts to fill at full volume, stops abruptly (without being complete), drum starts rotating, water starts cycling from side fill spout, and just continues to do this without advancing to wash or filling. I can manually skip to the wash cycle and the cycles for washing will advance as normal. Upon reaching the rinse cycle, the water barely trickles in, stops, drum spins and spins without filling, etc. Will not spin properly via the rinse cycle but will spin properly if advance to spin cycle manually. Thank you.
first check the resistance of the pump motor underneath at the right front of the tub the reading should be 7.1 ohms if its .3 ohms thats 0.3 less or more replace the motor. the motor is probbably running very hot, by the time it gets to drain its just gonna shut down.
My fisher paykel wash smart top loading washer Model #WA4127G1 just started banging loudly in the spin cycles (slow, med. fast ) ! We have adjusted the load evenly, checked water level, machine is balanced and stable ! What can be doing this? Wife is getting upset ! Anyone please help. Their website sucks, No help at all with live chat (Patience) . HELP !!!
Is it expensive to have a repair man come and look at our Fisher Paykel washer ? Where do I find a good, honest repair man ? We tried to diagnose the machine that keeps on banging in all cycles with an even load, water level, machine level too ! All I could do is unscrew the top control panel. There are no more screws or clips or any other access points visible. How do they get the back and top off of thes things ? ANYONE HAVE THIS PROBLEM ? HELLLLLLPP !
