Help! My dryer isn’t drying and we just replaced all 3 thermostats… The right side of the drum is hot but the air isn’t moving (the clothes are wet and cold)! I have cleaned all of the lint and nothing… Ideas?
Were you able to fix your dryer? Care to share what the problem was? We are in a similar boat with our Fisher & Paykel dryer. I thought it was clogged/blocked, but even after removing the lint from the filter ring and the back, it still won’t dry. There is some heat in the unit if I stop it in while it’s running. The fan in the back is suspiciously clean…
