The dryer heats but takes to long to dry . A service tech turned down the temp at one time because it was overheating due to improper ventilation at my apt. Now i have moved and it takes 3 hours to dry anything. Need to know how to turn the temp back up?
Hello,
This unit has no temp adj. I know this unit well and can say that for certain. You have a vent issue. 99% of the time the vent in the wall is clogged.
You would need to clean the vent or make sure the vent in the wall is not kinked.
My dryer is squeaking and not drying well. I can’t seem to find anyone to fix it. Help
