I have Fisher & Paykel washer (model GWL15) that is giving me grief. Stopped working the other day and turned it over to we if I could see something no luck. Flipped it back over and it worked. Now it over loaded itself with water and stopped altogether. Now it’s like it’s not even plugged in. Tried different outlets and no luck it like it shorted out. Any ideas???
there is a tech guide in the backsplash with a diagnostic program in it. chek for water in the control panel. if water most likely shorted board. sounds like other problems from what you say started it all. most likely turning it over is what put water in the board. before replacing board, check the pump, it could cause the original problem
