Firgidaire professional series dishwasher
Last week my dishwasher ran all night, not shutting off until I opened the door. I had to unplug it to reset it it seemed to work fine until today when it stop allowing me to choose any cycle except normal. It also does not run (motor or pump) but the timer will count down.
Replacement parts for FRIGIDAIRE PLD2560LCC1 Frigidaire/dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154476701.pdf
Sounds like a control board problem.
You may want to try removing power from the unit for 5 minutes or so just to see if it will reset.
You could try cleaning the connections but this is a long shot as a dirty connection should not make it run continuously.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
Thank you so much for your help. One more question, in your answer you said looks like a control board problem - does that mean i need to order both a control and a board?
Thanks Dale
It is just one part
AP3562736
It is just one part
AP3562736
Click on the picture for more info.
