Finding interchangeable washer motor
I have an older Maytag washer that only runs intermittently. Sometimes the motor will just hum. I turn the the motor manually by moving the belt a little bit and it starts. I am looking for a replacement motor and can’t find the same model. Does anyone know if there are any other motors that are interchangeable with my motor? The Model number is S68PXGCN 1002 and the part number is 6201660-16.
Thanks,
RT
What is the model number of the washer?
Eric
The Maytag washer number is LAT8506AAE
This is the replacement motor. It has a different motor switch and wiring harness connector and comes with a pigtail connection that you splice into your existing wiring.
Whirlpool 12002353 2 Speed Mtr & Jumper - AppliancePartsPros.com
Eric
