I need to replace all 4 Infinite Switches in my Whirlpool W5CE3024XB00 (Ser - D72008885) built-in cooktop. The electrical diagram on the bottom of the cooktop shows that I need the following:
2500w, 1800w, 1200w, 1200w (yes, that is 2 - 1200watt infinite switches). Unfortunately, I cannot discern what the wattages are on the Infinite Switches in the AppliancePartsPro inventory. Can you help me purchase the correct switches?
While the manufacturer does not specify the exact wattage ratings for each switch, they do list the following infinite switches for your model W5CE3024XB00:
- Left Rear Switch: W10861720
- Right Rear Switch: WP74007840
- Left Front Switch: WPW10326246
- Right Front Switch: WPW10244639
These parts are listed specifically for your model and should match the wattage requirements outlined in your wiring diagram. Let us know if you need any help with installation.
Thank you. These are what I will order.
