Hello,
I need some help with my Maytag Bravos EcoConserve washer(Model MVWX550XW1).
It recently started leaking water from the bottom of the unit. We checked the back - dry. The water connections and connection to the drain - dry. Something is causing it to leak. Any ideas?
It could the pump or any of a half of a dozen other things. You’re just going to have to get in there and look.
Here is a vid that might give you some ideas.
