Final spin does not work
Everything Works Until The Final Spin…it Seems To Go Through The Cycle But Never Spins
This is a Frigidaire made machine sold under the GE label. Inside the lower service panel should be some tech notes that will tell you how to generate error codes and put it in diagnostic mode.
It will also tell you how to test components, focus on the door lock assembly and the speed control board, those are the weak parts in this model.
