Fill valve won't stop
The fill valve won’t stop filling and water overflows out the door even after machine is turned off. I have checked the overflow prevention device and believe it to be working correctly. I recently changed the shut off valve under the sink, but I don’t see how that could be related. Please help.
Replacement parts for WHIRLPOOL DU6000XR1 | AppliancePartsPros.com
Sounds like some crud came loose when you replaced the shut-off and was able to get past the fill valve’s screen filter. This is now holding the valve open.
I would replace the units fill valve.
Is this part what is called “water Inlet Valve” ?
AP6007531
Item 26 in Section 2
Sorry for the delay was stuck at the lake due to a storm
