It is a Frigidaire FFHS2322MS9
My freezer is working fine but the fridge part is too warm. It alarms H1 with 5 beeps on the fridge side.
Things I have tried:
[*]Unplug refrigerator for 5 minutes to reset it.
- Check condenser coils at bottom back of unit for frost (no frost found).
- Replaced damper control assembly
[]Fridge is staying at around 15 C, I do feel some air blowing in though, but I do not know how much wind I’m supposed to feel.[]I tested continuity with every wire going into the control board, dampener and motor, all were good.
I tried the following tests in Service Mode
[]Test 3 & 4, FZ Thermistor & FF Thermistor tests, both flashing 1, not shorted or open[]Also tested thermistor in some cold water with a multimeter, confirmed resistance values correlated with temperature with a multimeter and temperature probe[*]Test 5, Damper motor test passes, opens and closes
- Test 6, Defrost test shows “d” for closed (the freezer was cold)
Are there any suggestions on what I should try?
Reading online, there are so many suggestions to what it should be, defrost heater, defrost thermostat, defrost fan motor, evaporator fan motor?
Are there any tests I can do to these parts before trying to replace them?
