FE error code on LG frontload Washer
I get a FE error code on my LG front load washer and the book says it is a faulty water valve. What part do I need to fix my problem?
When do you get the FE error code, right when you try to start it?
Does the washer fill with water?
You may want to check the screens in the water inlet valve to see if they are plugged up.
no the FE error comes on during the rinse cycle and the tub over fills and sometimes leaks on the floor.
