Fan runs continuous
Replaced wiring harness 318224945 now fan runs continuous. Swapped wires one for one color for color except where both wires were same color to a sensor or switch so as not to misswire. Would it make a difference on a sensor or switch if wires of same color were switched?
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318271934.pdf
[COLOR=“Blue”] Would it make a difference on a sensor or switch if wires of same color were switched?[/COLOR]
It should not make any difference as long as it is a two wire switch or sensor.
There is a possibility that it could be a 3 wire switch and you have it on the normally closed instead of normally open or vice versa.
