Fan Fell Off
The air circulating fan fell off and now it wont cool properly. How do I reattach it so it will stay? Do I need to buy a new fan?
what appliance is this fan for?
This is an Admiral Refrigerator
The fan motor supports may have weakened and the fan hit the housing, or the fan blade may be loose on the shaft. If the latter, replace the fan motor. If it came off, you may be able to use rubber cement to get the blade firm on the shaft.
Thank you, I will try the rubber cement. It seems to fit snugly, but it just works itself off.
