Factory Test Mode
How to enter Factory Test Mode on GE pdwt200v00bb?
take the bottom panel off. on the right side there will be a tech sheet stuck between the bottom of the tub and the metal it sits on. this sheet will give you the diagnostics information.
Look under the bottom panel for the tech sheet or behind the front panel should be a paper taped inside somewhere that shows you.
