F9E1 error whirlpool washer
Wtw5100hw0 wouldn’t drain, so I checked the hose for clogs. Checked the plug for continuity and nothing. I found a break in the wire so I fixed that. Check continuity and nothing, I cut the connector off and both wires have continuity. Now the problem is I can’t find the connector I cut off. I have female spade connectors on the wires but have no idea which wire goes to what terminal on the pump.
This is a simple 120v load, so it doesn’t matter which connector you put on which terminal at the drain pump.
Ok. That helps out a lot. I didn’t want to damage the pump. Thanks for the help.
