I have a 10 year old sears Kenmore glasstop oven and the burners on top of stove all work, but when I try to turn oven on and hit the bake button after 3 seconds it shuts itself off and F31 flashes…I tried unplugging it and plugging it back in but still does it…
F31 looks like an open oven sensor.
Below is a link with info on how to check it.
Look at 7, 8, 20 and 21.
http://www.applianceaid.com/electric-range-repair-topics.php
If the sensor checks out OK check the wiring to the control board and the connection for it on the control board. Could be a bad solder joint etc.
If all OK odds are that the control board is bad.
