F3 error code on Jenn air range model jds9860aap series # 22175375GJ
Brand:Jenn air
Model Number:jds9860aap
Main Symptom:f3 code and overheat
Error Code (if any):f3
Parts or tests already tried:had f1 code also - replaced temp sender. Still getting f3 code on higher heat (400+). Top of control panel gets hot. Need to see if you think new control panel will solve and verify correct control panel part - wp5760m302-60.
The F3 or F3-1 on this model indicates the sensor is shorted or open. If it has been replaced then you would need to check the wiring and use a multimeter to check the sensor and confirm it is good. If the wiring and the sensor check good then the issue could be in the electronic control. The tech sheet is attached and it has various test listed to confirm the sensor and the control.
tech-sheet-16026780.pdf (917.7 KB)
I bought a NEW sensor from your company and installed it. I am still getting the F3 error. I also tested resistance on the removed sensor and it also seemed correct, so it does NOT seem to be the sensor.
Testing the control panel is beyond my understanding of the diagrams and info sent.
Please verify - the F3 error could be corrected by replacing the control panel ?
Is the part number for the control panel I previously sent the correct part for my oven ?
Having re-read the control panel testing , I can try the ‘quick test’ procedure, however, the oven is turning on and functions generally seem to be working, but I suspect it is overheating…the error code we were seeing is only F-3 NOT F3-1 as in the material sent. Do you think this is the wiring harness and not the control panel ? How do I check the wiring?
