F3 eror code
erc clock started to speed up time then not work. replaced the erc control
and then showed f3 error code then replaced heat sensor still showed error f3. the erc was bought used is their a way to test the erc?
thanks,jim
Replacement parts for AMANA PHU186NWW Range - S/c S/i Ddraft Gas | AppliancePartsPros.com
[COLOR=Blue]the erc was bought used is their a way to test the erc?[/COLOR]
Not really but you can test the sensor and it connector with a meter and visually.
If it is OK then the erc is probably defective
Here is a good site on oven repair
http://www.applianceaid.com/elecrange.html
Check out #'s 7, 8, 20 and 21
