F2E0 Error on Model KSDG950ESS0
Brand: Kitchenaid
**Model Number:**KSDG950ESS0
Main Symptom: F2E0 Error/ Keypad Disconnected
What happens & when: I have replaced the control board and the control panel. When I use the blue wire harness that came with the control board I get the F2E0 error and the keypad does not work at all and I get the F2E0 error. When I use the original white wire harness the keypad works but then the F2E0 error comes back on. I can hit cancel and can use the keypad but then the F2E0 error comes back. I have checked all connections several times, powered off and on in between checking the connections. Any suggestion to solve this issue?
Error Code (if any): F2E0
Parts or tests already tried: New Control Panel and New Control Board
This issue would most likely be caused by a keypad that is faulty that would need to be replaced since the connections are ok.
Is the keypad the same as Control Panel that I just ordered from Appliance Part Pros?
Order 16662077 is the part I just ordered and tried
Hello? Do you think I was shipped a faulty Keypad/Control Board? I bought for APP and my order number is in this thread. Thank you!
