F2 Error code
[COLOR=#000000][FONT=Times New Roman]The Control Panel is beeping and the clock display is replaced with -F2-[/FONT][/COLOR]
[COLOR=#000000][FONT=Times New Roman]Pressing the Set button stops the beep & returns the clock display but only for about 1/2 minute.[/FONT][/COLOR]
[COLOR=#000000][FONT=Times New Roman]What is the F2 error code mean for this Gas Range?[/FONT][/COLOR]
Hi.
The F2 code means over temperature.
Check the temp. sensor and harness. The resistance of the sensor at room temp. should be around 1100 ohm.
The temperature sensor AP6024106
Here are the breakdown diagrams and Replacement parts for Amana AGDS901E RANGE- S/C S/I DDRAFT GAS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
