F2 codes on whirlpool oven
On my Whirlpool double oven I sometimes have an F2 code. Other times it beeps and the screen in blank. I searched on the internet and read for an F2 codes that I needed to replace the oven temperature sensor. My husband replaced it and I’m still have problems with the blank control panel or F2 code. If there is an F2 code, I can push start and the clock will come on and the oven will work. Other times, when the screen is blank, I can’t get the oven to work. Any suggestions on what it would be??
Replacement parts for Whirlpool RBD305PDQ7 ELECTRIC OVEN | AppliancePartsPros.com
See the attachment for the tech sheet. I could not find one for a PDQ7 so the tech sheet is for a PDQ6, the closest I could find. Odds are high that it will apply to your unit.
It shows F2 as a keypad error not a oven sensor error.
I would try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. If it has a connector on it use electronics contact cleaner or isopropyl alcohol.
RBD305.pdf (200.2 KB)
