F10 error code on Kenmore oven/range
Brand:Ken more
Model Number:79097503002
Main Symptom:lower oven over heating
What happens & when: Lower oven comes on and does not control to temp. Oven gets so hot the F10 error code appears and sets off an alarm that can only be clear by cutting off the power
Error Code (if any):F10 error
Additional info to the original topic - upper oven and cook top work fine. According to some YouTube posts the Electronic Control Board or the oven temperature sensor might be bad. Sensor has been cleaned but made not difference.
That is going to be either a stuck relay on the control board or a grounded out heating element. I would probably start by checking each of the lower heating elements to chassis ground for continuity.
