I have purchased a Electronic Control Board for my washing machine. Does anyone have any instructions on how to replace it? I saw a video on a website and it looked fairly easy to do, but now I can;t find the video any longer.
Thanks much, Ruby
Here is a link to a service manual for your model, that should be better than a video.
Thank you, thank you, thank you for giving me the link to the instruction manual. You are a PEACH!!!
I’ve ordered the replacement part and will use the instruction manual to replace it. You have saved me a ton of money. If I ever meet you in person I will hug your neck.
Ruby
Well thank you, glad to help. It seems like you do all the work and we get all the thanks.
Good luck with your repair, let us know how it turns out or if you need additional info.
From what I can see on the instructions, I have to remove screws from the back, remove UI connector, remove knob, unhook harness from cover, remove 3 screws from UI board, unclip and remove UI cover from console, remove encoder, remove user interface board and then reinstall encode making sure that the rubber seal is not dislodged and then rescrew everything back in…correct.
