F1 code and beeping sound on my electric slidein range. Burners work on top but oven does not work. When pressing the oven cancel button on the panel the beeping stops. Maunfacturer:PACS727OASO Serial # 0111164129
The “F1” error code means a shorted input pad. The suggested solution is to replace the membrane switch.
- The membrane switch AP6007879
Here are the breakdown diagrams and Replacement parts for AMANA ACS7270AS RANGE- S/C S/I ELE | AppliancePartsPros.com
