Extending Drain Hose
Can I add 10 feet of discharge hose from the washer?
I see that there is a ‘48 in.’ extension drain hose available…essentially I’d like to add 2 of them together to maximize space..
Go to the Whirlpool site with your Model Number perhaps there is an install sheet that will help.
Without more info about the plumbing set up etc. cannot say.
You may have to install an air gap.
