Exhaust fan not working
Nothing happens when you push the fan button, no beep or anything. It’s over the range so very necessary.
I tried unplugging for a Long period and it didn’t work.
Again model is hvm1750dm1cc. It’s in cream/ bisque color.
What do you think?
If it does not beep then, most likely, the problem is a bad key pad. It comes as a part of the control panel.
I think it is due to the bad wiring.
I think it is due to the bad wiring. Check the connections again, there must be some issue in it.
nutone bathroom fans replacement parts
no beep. control pad. take Genes advise
