[LEFT][COLOR=#000000]Standard freezer on top fridge model;
Found water on freezer floor a few days ago. Freezer working fine temperature-wise. Checked the fan at the top rear of the freezer. It was running fine but somewhat obstructed by a bag of frozen food. I corrected this obstruction but no improvement.
Next day I removed the cardboard dust cover at the rear base and vacuumed out a large amount of dust from the various components. Found that the trap bend of the formed hose running to the evaporation pan was completely plugged. I removed it and cleaned it–turns out the large diameter/flared end (which is a slip fit on the rigid defrost-drain tube running down the back of the fridge) is a nice snug fit when jammed into the inside of my laundry tub spigot which has a standard male garden hose thread end. Water pressure was a much better method than my initial efforts with a few different rigid and flexible objects.
Reinstalled the clean hose plus dust cover and restarted unit. Still seeing some moisture on the freezer floor but not as severe as the initial problem.
A day later I checked the drain hose and it looks fine–trap section full of water so I assume there is no upstream blockage. Is this a correct assumption?
Any other thoughts on moisture sources in freezer?
[/COLOR][/LEFT]
