My dryer (FER231AS2) is venting the lint under the dryer not the exhaust vent. The semi-rigid exhaust tubing is secure at both the dryer and the wall. Would like to know what might cause this and how easy it is to fix.
thank you for your reply. I realized after posting, that it is likely the exhaust being clogged and will be checking/cleaning that and the interior soon, with fingers crossed that it is the problem. Since it is now running hot even on low heat, I’ll be drip-drying my laundry in the meantime so I don’t cause any further damage
all the best
