HAVE A SMALL 11.7 CU FT EXCELLENCE BRAND REFRIGERATOR WHICH IS NOT FROST FREE. WAS GONE 2 MONTHS & WHEN I RETURNED EVERYTHING WAS FROZEN IN THE REFRIGERATOR SECTION. I RAN A TUBE DOWN THE DRAIN PIPE & THERE WAS NO BLOCKAGE. I DEFROSTED THE FRIG TWICE. i SET TEMP CONTROL AT DIFFERENT LEVELS & AT 1 SETTING (WARMEST SETTING), THE FRIG WAS 19 DEGREES & THE FREEZER WAS -19 DEGREES. I RAN A CONTINUITY TEST ON THE TEMPERATURE CONTROL & IT WAS FINE. THERE IS NO PANEL TO REMOVE IN THE FREEZER, & NO HOLE FROM THE FREEZER TO THE FRIG TO BLOW COLD AIR. IN FACT I CAN’T FIND AN EVAPORATIVE FAN ON THIS FRIG. THERE IS A PANEL IN THE BACK WALL OF THE FRIG, & THE TEMP CONTROL DIAL IS ON THE INSIDE WALL OF FRIG.
I WONDER IF THERE ARE PARTS AVAILABLE FOR THIS 24 YR OLD EXCELLENCE BRAND FRIG. ANY SUGGESTIONS WHAT TO TEST NEXT, & WHAT THE PROBLEM COULD BE? THANK YOU
was wondering if you could help me with troubleshooting this Excellence frig (please see first post for details & what i tested to date) because right now i have no frig that is working right. there is a plastic piece/cap that fits over the upper R back of the frig which is about 5"Lx 3"W, & about 2" deep just below the freezer—is this where an evap fan would be housed? thank you!
was wondering if you have any ideas about troubleshooting the excellence frig cause right now i have 2 frigs & neither are working properly. there is a plastic cup closure over the back of the frig (about 3"w x 5"l x 2" depth just below the freezer on the R side back of frig)—could this be where an evap fan motor would be housed? i don’t ever recall hearing or feeling a fan motor blowing inside this 11.7 cu ft frig.
there is no panel to remove in the freezer but there is a panel in the top back wall of the frig & i imagine that’s what has to be removed.
any suggestions what else to test? this is not a frost free freezer. would attach a picture but don’t know how to get it in a url. thank you!
Attached 2 photos for Excellence Frig. Look forward to your response.
