evaportor fan issue
The evap fan motor is not working on this model, replaced the motor with brand new one still nothing, checked for voltage have 13.74 at the white and red wires, and 13.54 at the white and yellow what about the blue wire, possibly a bad new motor?? Thanks for any help
Perhaps this STICKY at the start of this forum will help.http://forum.appliancepartspros.com/refrigerator-freezer-repair/4220-ge-refrigerators-gs-ps-models-evaporator-fan-motor-test-replacement.html
It has a lot of good info from Gene and Richappy
tried everything in that post have correct dc volts at the red and white wires and white and yellow but motor dosen’t run ( new motor) anyone else with any ideas
[quote=denman;128708]Perhaps this STICKY at the start of this forum will help.http://forum.appliancepartspros.com/refrigerator-freezer-repair/4220-ge-refrigerators-gs-ps-models-evaporator-fan-motor-test-replacement.html
It has a lot of good info from Gene and Richappy[/quote]
Replace the evaporator fan and it doesn’t shut off when compressor shut off. Freezer is cold/frozen food as well as refrigerator. What could the issue be
You are missing a square wave at the motor, replace the motherboard
