Evaporator Frozen
Evap frozen again about a week or so after a manual defrost. Measured continuity of 20 ohms on element. Timer rotates, the 120V, 8.5 hr cycle type unit…and it seems to shut off and turn on the freezer appropriately. Kind of a tight squeeze to get into the freezer for checking components so is the thermostat clamped on the top evap tube the issue, not closing to allow the element to heat, should read closed I believe until temp reaches >15F? I did notice heat damage to the lower right cabinet edge near the evap coil approximately 3" in length and 1" of the cover seal is melted away same area. Good machine. Everything cleaned well during the last manual defrost and all fans and compressor are working, although I believe the compressor was thermal shut-off cycling, and may be doing so again. My intention is to remove all food and shut down the unit to slow defrost versus hair dryer this time, and to give me time to procure the parts.
After reading some more of the forum replies to similar problems I am going to measure the thermostat in it’s frozen state and I do think it is bulged the last time I saw it…easy enough to test and replace and since the element is measuring the correct resistance, should cure the problem. Take care. DG
