evaporator fan
2 year old fridge freezer on top fresh on bottom. fridge is not keeping cold .i can see Thu the vents and feel that the fan is not working.ok here’s the thing ,i can put a small stick on the fan thru the vents and flick or nudge it and it works fine throughout the cycle.when fridge stops cycle fan will not start up with out help. can i assume its a bad fan motor or can their be more.
[quote=ltd;638125]2 year old fridge freezer on top fresh on bottom. fridge is not keeping cold .i can see Thu the vents and feel that the fan is not working.ok here’s the thing ,i can put a small stick on the fan thru the vents and flick or nudge it and it works fine throughout the cycle.when fridge stops cycle fan will not start up with out help. can i assume its a bad fan motor or can their be more.
[quote=ltd;638125]2 year old fridge freezer on top fresh on bottom. fridge is not keeping cold .i can see Thu the vents and feel that the fan is not working.ok here’s the thing ,i can put a small stick on the fan thru the vents and flick or nudge it and it works fine throughout the cycle.when fridge stops cycle fan will not start up with out help. can i assume its a bad fan motor or can their be more…thanks
