Evaporator fan not running
Just replaced both the circuit board and a new evaporator fan motor, but the fan is still not running. The evaporator coil freezes up and I can hear the compressor running, leading me to believe there is sufficient head pressure. How can I make the fan run?
Replacement parts for AMANA SXD25AW REF - SXS/I&W | AppliancePartsPros.com
I could not find any tech info on a SXD25AW.
See the attachment. It is for a SXD25S2E.
I am assuming that it will be close to yours but this could be incorrect.
[COLOR=“DarkRed”]Just replaced both the circuit board and a new evaporator fan motor, but the fan is still not running.[/COLOR]
Was the above replaced just because the evaporator fan was not running?
[COLOR=“DarkRed”]How can I make the fan run[/COLOR]
If the answer to the above is yes then it could be that the problem is just the defrost thermostat.
To check unplug the unit and measure the defrost thermostat with a meter. It should be 0 ohms when frozen.
Note: it opens just above freezing.
If there is no ice /frost on the evaporator coils hold the face of the thermostat onto an ice cube to get it to close.
If it does not close it is toast.
SXD25.pdf (1.1 MB)
