Evap Fan Motor
Can you tell from my Model Number weather I require the replacement part with or without the Thermistor??
Hi John,
The best way is to remove the rear panel in the freezer and check what kind of the evaporator fan is installed now.
  • The evaporator fan motor without the thermistor AP3875639
  • The evaporator fan motor with the thermistor wired into the plug AP3191003
