Evap Fan does not run
Brand:Samsung
Model Number:RF28HMEDBSR
Main Symptom:Evap fan does not run
What happens & when: What voltage should the controller send to the evap fan? I’m seeing 1.6 Vdc when I command the fan on using the diagnostic mode. Trying to confirm if problem is the fan or control board.
Hi caldrir, is it the evaporator in the freezer or the one in the refrigerator section?
In the refrigerator section.
Hi caldrir, your unit does have a service bulletin related to this issue. I’ve attached it to the thread for you to review.
ASC20171005001 (1).pdf (544.4 KB)
