The oven on my Estate gas stove has had intermittent issues remaining on after the preheat cycle. It will preheat fine, but then it won’t continue to stay on and cook - it will cycle off and can’t be restarted.
Any thoughts or suggestions on what could cause this will be appreciated!
Most likely it’s a bad control board/clock.
It’s no longer available, contact the manufacturer for the info on rebuilding the old one.
But before replacing it check the oven sensor resistance.
Should be around 1100ohm at room temperature.
