Estate by Whirlpool Electric Dryer
My Estate by Whirlpool electic dryer runs, but the knob does not advance on any setting. Also, it does not heat.
Replacement parts for WHIRLPOOL TEDX640PQ1 29"ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram
When you say “the knob does not advance on any setting” does this include timed dry?
In timed dry the timer motor gets power directly from the line through Timer Switch 0.
In auto modes it gets power through the heating coil when the coil is turned off by a thermostat.
If the timer advances in timed dry but not auto then odds are the heating coil is burned out.
If it does not advance in either mode you could have a power problem, the centrifugal switch is not closing or the timer motor is shot.
I would start with the power.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
WED5300.pdf (505.7 KB)
