ERSD F2 & F4 Fault codes
When using the left oven I get an F2 fault code and when using the right I get an F2 or F4.
I checked the ohms on both oven sensors at 65F and at 100F and found the resistance to vary with the temperature as expected and the values be relatively close to the values the service manual specifies.
Before I bite the bullet and put out $320 for a new ERC, is there anything else I should check?
Hi.
Based on the information you provided the ERC is defective.
62692
Here are the breakdown diagrams and Bezel Assembly parts for Dacor ERSD30 - AppliancePartsPros.com
Simon.
