Brand: LG Model Number: LFXC22596 Main Symptom:Door Ice Maker not working What happens & when:
Error Code (if any):IF E
Parts or tests already tried: No water in mold, water dispenser works, freezer ice maker works. Suspect water flow valve but which one?
Thanks. Would that be the fan that circulates air in and out of the vents between the refrigerator body and the door? If so, how can I activate that fan and should I be able to feel the air blowing?
One fan circulated air from the freezer for cooling, a second fan blow air to the ice maker. Normally it should be running when the refrigerator is running.
