Error Codes
My Frigidaire (Electrolux) washer stopped working in the middle of a load and gave error code E24, which says “drain pump relay on control board failed” and to replace console control board.
So I spend $150 with overnight shipping and change the board, of course now I get a NEW error code: E59 “no taco signal for 3 seconds” refer to test 10.
I am unable to identify the pin numbers to measure the tub motor ohm readings as indicated in the corrections column.
Anyone have any ideas on the motor plugpinout sequence?
Thanks,
Jack
Nevermind, I found the pinout on the wiring schematic.
Thanks for reading!
