Error Codes E23 and E30
I have a GE WCVH6800J1WW and getting error codes E23 and E30. I took the pump off and it’s working fine when 120V applied. I don’t get any voltage when I remove the pump and perform the t05 pump test. Should I get voltage at the pump WITHOUT the pump installed…if so I’m not getting any.
Ideas? Thanks,
If the machine should be sending voltage to the pump then your test device should show 110/120 v coming to it. Sounds like the control unit is not directing voltage to the pump when it should, or less likely that there is a problem with the wiring.
