Error codes E0 F0
One day after trying to self clean the oven, these error codes appeared. The display The oven panel buttons are all dead, but the stovetop works fine. The oven door is unlocked. Help!
E0 F0 is a communication failure within your control board. If it does not reset after a 30 second power down, the board will need to be replaced and I would need a complete model number to help find the part.
