Error code
We have a Kitchen Aid gas range with error code F2 E0. Display says “Err stuck key”. What does this mean and/or what part do we need to order?
Thanks for any help!!
Replacement parts for WHIRLPOOL KGRI801PBS00 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%209761385.pdf
Here is a service manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/31b22701e542b5fe85256f0e00472272/$FILE/kac_42.pdf
Error means that one of the bubble switches in the keyboard is shorted/collapsed.
Try the powering off of the unit first, just to see if it will reset.
If not the service manual does give the pinouts for the keypad. Using this and a meter you should be able to find/confirm that a key is shorted.
Then replace the keypad. Otherwise you are relying on the units diagnostics to tell you the keypad is bad and this is a bit of a crap shoot.
