Keypad no. 5 & 0 does not work when pressed. When oven reaches desired temp. it would start beeping & only way to stop it was to cancel.
A model number may help others help you
[quote=2004chev;274120]Keypad no. 5 & 0 does not work when pressed. When oven reaches desired temp. it would start beeping & only way to stop it was to cancel.[/quote] MDL# KEBS107DAL4 KitchenAID OVEN
Replacement parts for WHIRLPOOL KEBS107DAL4 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%204454769.pdf
Here is a manual, although it is for newer units it may come in handy
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6342e2edf7772b6e852573440054cfc6/$FILE/4317418%20Single%20Wall%20Oven.pdf
Try removing power from the unit for 10 minutes or so to see if the control board (EOC) will reset.
The error you see is related to cavity size but this does not make sense as it is jumper settings and they are not going to change. This points to a bad control board.
Does sound like you have two different problems. One the error code and the second the buttons not working.
Unfortunately there is no info available for the keypad which would allow you to check it with a meter. Buttons not working can be either the keypad itself or the control board.
You may want to try the following. On most keyboards a number of keys will use a common circuit (track) and that may be why more than one key is not working.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
