Error code E6 F2
I have an error code E6 F2. It will go off and on, can get it to stay on a little more than 1/2 the time. Especially if I have the breaker off and turn it on, I can usually get it to stay on after a bit, at least longbenough to cook something. What part/s are most likely a problem? Thanks.
Parts for Whirlpool GBD307PDS10 Wall Oven - AppliancePartsPros.com
I would try the following first
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If this does nothing I would replace the control board/timer.
This is a bit of a gamble but since shutting the power off resets it.
It is the most likely.
GBD307.pdf (504.3 KB)
