Eoc board on stove
When cooking dinner, the control panel flashed f1. I followed the trouble shooter and waited 30 sec. or more and plugged stove back in and the f1 again appeared. you cannot set clock or oven temp. Please give me some info. on this matter. Thank You. Joann
If the error came back after a power off, then the electronic control has failed ([COLOR=#0000ff]AP3764682[/COLOR]) and needs to be replaced. It is a quick replacement requiring only a few screws and moving over the wiring harnesses. The overlay from your current control will peel off and will stick to your new control. Hope this helps.
