I’m having trouble finding a fuse for my microwave. It is a short ceramic fuse. It reads f15h250v.
I can only find ceramic fuses that are 1 1/4 in. If someone could help me locate one, I would greatly appreciate it.
I also thought about just buying a fuse holder and using the longer fuse. The only problem I see with this is that the fuse goes into a solid state board (noise filter). I could put a slug in it and just run the fuse after the noise filter. I could also put the fuse in before the noise filter with some modifications.
